I have a 1987 Alpha one Gen 1 that I am replacing shift cable, bellows and trim sensors. While I'm in there I want to replace anything that might cause a leak or other problems. I notice a little play in the upper bellhousing shift shaft (only front to back) and am concerned about the seal there. I went to my marine dealer and he didn't have the bushings in stock, so he was going to have to order them. When he looked up the parts, there was no mention of superseded parts or an upgrade kit. I've seen mention online of an upgrade kit that has 2 bigger seals pressed into a larger version of the bushing and it is supposedly better. I think the part number mentioned is 23-805041A2.
Should I replace the current parts with exact replacements or should I find this upgrade kit? If there is an upgrade kit, will it fit my 1987? Do I have the correct part number? Are aftermarket kits available and OK for this application if I can't get the OEM easily?
