just replaced water pump in my alpha one drive.. replaced gear oil... now i have gear oil leaking from what seems the exhaust water via prop.. oil is getting into the exhaust water ..only started up and run on with earmuffs supplying the water.. not been in water as of yet. now to the horrible truth. .. when reinstalling the lower drive the shift didn't quite couple up and got jammed.. released pressure on lower half and guided the shift shaft into place then re bolted up do you think this may have damaged some seal hence causing the leak. although the leak isn't from the shift shaft..
all input would be appreciated before i dismantle. i know i have to but would be nice to know where to look..
when i run before i noticed leak it went into gear well and run good.. no strange noises.. lets hope i haven't done too much damage..
