Hello ALCON,
Please forgive me up front as this is my 1st boat and my boating terminology is elementary. I bought this boat as a project boat and a project it seems it is going to be. For starters I think I may have a shift cable issue. I have removed the drive unit from the bell housing and removed the lower unit from the upper unit. I have "borrowed" the shift shaft from the upper unit and placed it on the shift crank pin in the lower unit so I can simply shift from forward to reverse. If I move the lower shift pin to forward and spin the drive shaft clockwise, the propeller shaft will also spin clockwise. If I try to spin the propeller shaft counter-clockwise, it locks. I then reverse the process and move the lower shift pin to reverse, spin the driveshaft clockwise, the propeller shaft will spin counter-clockwise; and if I try to spin the propeller shaft clockwise, it locks. I think so far so good?? This like here is a video to my YouTube page just showing this http://youtu.be/UoCglsXrtk8
Now when the lower/upper unit were put together, before I took it all off, the issue I was having was that the shifter would shift fine...as in it was not hard but easily to move from forward to neutral to reverse. When I shifted into reverse the propeller shaft would engage and spin counter-clockwise. However, when I shifted into forward, the propeller shaft would never engage and you would hear a clinging noise. Is this an indication of a lower shift cable issue?
With the drive unit off, I can see when the shifter is shifted into reverse, the shift slide move forward and I am not able to pull on it. However, when the shifter is shifted to forward, the shift slide move back and I am easily able to move the shift slide forward and back with ease. Is this normal and is potentially my issue? Could it still be a lower unit issue? Here is a link to my YouTube showing this http://youtu.be/nO5RfsLU-JU
Please Advise and TYIA,
Gary
Gary
