Alpha one gen 1 to gen 2 conversion
eric416
I have a mercruiser 3.0 with a tired alpha one gen 1 on it. It has a cracked lower unit and the trim cylinders are in need of a rebuild. I found a great deal on an alpha one gen 2. Would it be possible for me to use it if I get the gimbal housing/transom assembly with it? Basically, what would be needed to do the conversion. Reason im asking is I could buy a gen 1 for $400 and then change the impeller or get the gen 2 with the housing and trim cylinders for $150.
Rick Stephens
If you change the gimbal housing back then it is bolt right up. The internal transom plate is the same the components on the outside all need changing.
RIck
Ayuh,.... Seems like alota work, for a couple hundred bucks,....
Everything aft of the rear motor mounts is changed,....
