I have a 1978 Sea Ray 220 Overnighter that I have been restoring for a while even while using in the summer. It's been about three years since I did bellows and impeller so I decided while I was redoing my floor/removing carpet, I would also do maintenance work. That's where things went odd. I removed the water pump and my base is very odd, I can't find anything like it on the internet. I have attached a picture. It has a "pin" in the plastic piece that surrounds the shaft and a corresponding hole for the pin on the current base. I would simply use the old base, but the 5/16 screw doesn't get tight so it appears it's stripped. Did the base somehow separate and now I need to get the part with the "pin" out so a normal base will fit? Any suggestions? This is an Alpha One Gen 1 outdrive, Mercruiser 5.7L.
