Alpha one Gen 1 water pump/ impeller issues
Austen2000
1987 Chaparral 170xl
3.0 GM
Alpha One Gen 1
Please forgive as this is my first boat and drive to work on. I've been reading posts for a couple days and can't seem to find this answer.
I purchased 18-3217 is that the correct impeller kit?
If so I think there are extra parts I have removed upper water pump housing, impeller, gasket, face plate, gasket and the key. How do I take off the lower pump housing or does it come off? Other wise I have to many seals and gaskets with this kit.
Also is the a gasket for the shift bolt at the front of the lower unit?
I have used this as an example
Alpha One parts / lower gearcase drawing
Thanks :laugh:
ktbarrentine
Re: Alpha one Gen 1 water pump/ impeller issues
There are extra parts in the kit..... Just replace the ones you pull off. Your manual (the "right" OEM manual) provides the details on how to get your lower pump housing off. (did your kit come with a lower pump housing. or did you buy one separate? If not, then dont mess with it unless your pressure test shows you the seals are leaking.)
Don't understand this question:
"Also is the a gasket for the shift bolt at the front of the lower unit?"
See this thread for the instructions:
http://forums.iboats.com/mercruiser...oblems-after-impeller-replacement-607425.html
And/or this one:
http://forums.iboats.com/mercruiser...cellaneous-mercruiser-information-329915.html
alldodge
3.0 GM
Alpha One Gen 1
Thanks :laugh:
Your fine, the impeller is the same and your OK. The kit contains different gaskets for the pump differences from MR to gen 1. The lower housing does not come off for an impeller change. See below on how to
http://forums.iboats.com/mercruiser...placing-merc-alpha-style-impeller-387864.html
ktbarrentine
Not sure how/where you have been searching, but a simple search of this forum for "Alpha impeller replacement" or "alpha impeller instructions" brings up more info than you can read in two days!! Just sayin'
Austen2000
ktbarrentine Thanks I was concerned about the extra parts.
There is a rubber washer over the shift bolt on the lower unit? This is shown in the third picture I posted I did not know if there was a replacement for that it is really worn. But with AllDodge's link (THANKS) there is suppose to be a stainless steel washer over the rubber washer. Which I found in the bottom of the unit all bent up. Guess I need to find a new part number for this.
Does the bottom of the water pump housing even come off on a Alpha one Gen 1? If so help would be appreciated.
I would like to make sure everything looks good while I have the lower unit off and changing the impeller.
Bt Doctur
The lower base comes off prying with 2 screwdrivers from each side. Most replace the base instead of replacing seals If those are your pics, your missing the SS washer that goes over the lower splined shaft.
Austen2000
Thanks Bt Doctur, I found the washer in the bottom of the lower drive. I had to turn the unit over and it fell out and I know it was not on when I took it off. I will try to pry the lower base off as you said.
Is there a easy way to pressure test the drive?
The boat has been sitting for about 9 years before I got it about a year ago. The engine runs great after I got it to start. Now I am working on the drive , billows, and shift cable. If all checks out then I will redo the interior ( everything is mostly rotten). If not may have to part out what I have. I call her the BEAST at least for now until she runs on the water for me. I'm attaching a pic for everyone to see.
Austen2000
Or what size the insert is for the drive to do a pressure test and where to find one? I have a compression gauge to do it.
Thanks
Thanks
Ayuh,... Welcome Aboard,... A Cork, or rubber stopper of the right size will work,...
yer compression gauge Won't though,... it can't read low enough,...
Ya only need 10/ 15 psi,...
Austen2000
Bond-o. Thanks
So, I guess I can buy a cheap pressure tester from auto parts store. Guess I can use the end of a gear oil pump for the fitting.
Bond-o. Thanks
Ayuh,... That's the Quick, 'n Easy way to get there,... ;)
nola mike
Do a search for pressure tester. yes, use the fitting from a gear oil pump connected with some clear hose to a valve stem. Pump up with a bike pump and use a standard tire pressure gauge to measure the pressure.
ktbarrentine
ktbarrentine
12-31266 for the rubber washer; 12-29395 for the SS washer
Austen2000
Thanks ktbarrentine, I will order those washers. I just bought a pressure gauge at Harbor Freight today to make a compression tester.
after I get the drive back together.
Can you buy washers only for the upper and lower drain screws? Or do they just come with the screws. Part #?
I can't wait to get this unit together and fire it up! :rolleyes:
ktbarrentine
Most impeller kits come with a couple of vent/drain screw washers..... They probably have them at the counter of the boat store. Otherwise, part number is 12-19183. Amazon has them for a buck a piece. I usually try to have a dozen or so laying around.
