I hav a 96 bayliner wit 5.0 and alpha one gen 2 I had a crack in my lower unit so I bought a used unit on eBay and after I installed it I ran it everything was in check except after I shut it dwn and whiped it all dwn I noticed there was a small amountof gear oil dripping out of those 2 little holes one on each side of the lower. Unit rite below the bolts that hold the upper and lower together. And while the motor is on water is forced out of these but once shut dwn is when the oil starts dripping could this be severe or simple as a bad seal on the drive shaft. I was goin to take apart the cracked unit to kinda investigate b4 I did it to the newer one thanx!!!
