alpha one gen 2 mercruiser where is water pick up on drive?
jayh
1997 is the yar
i want to check and see if there is some debri or somethign clogging the water pickup from the drive. where exactly is it? i looked in the manual but couldnt find it...can i do this in the water?
mrmushroomman
Re: alpha one gen 2 mercruiser where is water pick up on drive?
Your water pick up is towards the lower end of the lower unit. You will see a fan like opening on both sides. There is a screw or two holding it on . This is were you put your muffs on when running the boat with the gaden hose
Nope,....
And it Won't make your Bad Impeller any Better either....
180shabah
What manual did you look in?
