BETZ954
- Jun 6, 2009
- 52
OK so I've changed my drive oil an some of it was alittle milky.. so im gonna tear it down an do some over do maintenance.
it wasn't real bad but their is a small bit of water getting into the oil some how.
It is my first time in a mercruiser im use to old volvo/pinta, so ill be learning as i go..
First im ordering parts an i hope to get everything i need before i tear into it so im not waiting on things while half way into it.
Next i ordered a water impeller kit, the one that comes w/ base carrier.
And i heard alot about shift shaft bushings going bad. Is there a kit for that i could get an does anyone have the part #'s for it.?
Also is the anything else anyone would recommend changing while its apart.? other then bellows, had those done in the spring.
My alpha one gen 2 is a 1991 with serial # OD563241
