Falcon-
- Jul 6, 2009
- 27
A bit previously I had issues with a leg oil leak in my Alpha One Gen II leg (leaking from between the upper and lower housings). At the time I got some great advice and found the culprit was simply a missing quad ring seal. After replacing that the leak stopped and after waiting a week with no new oil showing up I declared the problem solved.
Well after a couple weeks sitting in the driveway while I worked on other parts of the boat I once again have an oil leak.
This time the leak is showing up in a different location - the oil is leaking out of the water inlet holes in the lower casting, mostly on the startboard side. The leak is very slow but unmistakeable.
Could this have been some oil that was trapped in the water area when I took the leg apart to replace the quad ring, or do I have a larger problem here?
My pessimistic side says that it took far to long to show up to be just oil from the previous leak....
FWIW this is a 1992 vintage Gen II leg.
- Sean
- Sean
