Alpha One Gen II
Provo5
I just replaced my impeller now I have gear oil leaking out of the starboard side between the upper and lower housing. Did I need to put RTV there or something.
Bt Doctur
Re: Alpha One Gen II
sounds like you forgot to install the small O ring seal between the units, called a "quad seal"
Provo5
You would be correct, I have the small o ring but did not know where it went.
Where should it go. Thanks for the info
Bt Doctur
Where the yellow is.
