Hello,
New Boat Owner here: 1986 16' Peterborough Monza with a MCM140/Alpha one. The Alpha One, Gen one, is leaking oil from the Weep hole. So I am replacing the Shift Shaft seal and bushing, along with replacing the Impeller, gaskets, and both the top and base of the Impeller housing. I will pressure test unit before re-install.
My questions are in regards to the vertical Drive Shaft. With this older drive, I have the O-ring groove just below the spline. When I removed the lower unit, I found this O-ring had come off and was sitting up in the Upper Unit where the Drive Shaft seals are. I also found what appears to be another piece of a similar size O-ring up there. Must have been from prior owner.
Q: Do I install the shaft O-ring or not? I have read yes and no.....
In the Upper unit, where the top of the verticle drive shaft slides into the Upper unit, there appears to be 2 seals. I'm trying to interpret the drawing in the link:
http://www.iboats.com/Mercruiser-St...8891364--session_id.577619652--view_id.272967
Q: What seals are used to seal the verticle drive shaft in the Upper Unit? Is there suppose to be an O-ring up in there in addition to the O-ring on the shaft?
part numbers 14 and 13 appear to have different ID's.......
Q: Can these seals be replaced from underneath?
thx
Petch
thx
Petch
