Is this plate adjustable? The switch doesn’t seem to go into the slot in forward.
M Murphy1600 Cadet Joined Aug 11, 2024 Messages 10 Oct 25, 2024 #1 Is this plate adjustable? The switch doesn’t seem to go into the slot in forward.
nola mike Vice Admiral Joined Apr 22, 2009 Messages 5,463 Oct 25, 2024 #2 It isn't really adjustable, but a corroded/sticky pivot bolt can keep the plate from moving freely. The return spring can also have the wrong tension, which may make the plate harder/easier to move in one or both directions
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,357 Oct 25, 2024 #3 Do you understand the switch operation? It only operates coming out of gear ,in the water with a load on the prop. The manual has the adjustments
