Alpha One Gen Two Thrust Hub Removal
Gunmetallude88
Long story short….went out one day on the water and then parked the boat in the drive way with the drive in the down position. The next day I come outside to see gear oil on the ground and my reservoir empty in the engine bay. Did some investigating and found it leaking through my bellows. My bellies had a hole in it compromising the upper drive seals. So I have the drive removed from the boat and the drive separated upper and lower. On the lower unit I have removed the bearing carrier but doing so left the No. 14 Thrust Hub in the lower unit. I have tired getting underneath it to pry it out but no luck. Do I need to remove the prop shaft? The only reason I wanted to was to replace the bearings and seals. If anyone could give me some advice I would greatly appreciate it. I have the special tools except to set the preload.
Bt Doctur
Try spraying with a penetrating oil and try rocking it side to side?
Gunmetallude88
Thank you for the reply I will try that. I’m just afraid of breaking something. Could I grab the hub of the reverse gear to help pull the thrust hub?
Bt Doctur
what are you calling the thrust hub? Bearing #15 is pressed onto the gear and usually comes out with the carrier
