Heya!<br /><br />Replaced my bellows and gearshiftcable and adjusted it according to the manual. (even twice)<br />But when i move the thrustlever into first position (forward-reverse) the propp does not engage into gear only this clunk clunk clunk sound....<br />However, when movin lever full (any position) no problemo, gear engaged.<br /><br />Also, the killswitch (wich i remember was moving last year with old wire) does not move anymore..<br />Well, it moves when i use my finger and pushes on it.<br /><br />When i changed the belows and gearwire i had to turn the drive from outside port-starboard several times to be able to do the job.<br />After awhile i noticed when i had the drive to Port it got stuck in that position, but it came loose afterfew minutes.<br />But from now, everytime i turn the drive by hand from outside to Port i got this problem...<br />And i imagine how safety it must be cruising or docking with this issue.. err NOT
<br /><br /><br />I hope that ppl can read, and what i wrote make sence.Im not that good when it comes to enigne terms and other techincal related things since im not native English speaking.<br /><br />Thanxs in advance
