Alpha One/ Gimble
jth21usa
Here is the problem, the boat make a wierd noise when I turn starboard and takes on water only when I'm moving. Is this the Gimble bearing and or he bellows? I have read this is best takin care by a shop. How much should that cost so I don't get killed. Also I just changed the impeller, could I have screwed this up in a way that would create these problems? Any help would be awesome. The boat is a freshwater 1994 235 Mariah Davanti with a 5.0 lx mercruiser, alpha one out drive.
Justin Hafner
Bt Doctur
Re: Alpha One/ Gimble
Wont know untill you pull the drive and look. water in the bellows could affect the input yoke(rust) and cut the seal.Main bellows and shift bellows are prime suspects for water leaks
