Alpha One hinge pin torque
CHARGER2
I am installing the bell housing after a new bellows install (first time for me) and need to torque down the hinge pin bolts. I know the service manual says to torque to 95 lb-in, but (from previous experience) that seems very high for bolts this size into an aluminum housing, and I am afraid of stripping the housing threads. Has anyone had bad/good luck with this torque value?
1990 4.3 alpha one gen one.
Regards
dubs283
Re: Alpha One hinge pin torque
torque spec varies from mc-1 through alpha one, you can even read different torque values for the same model in the same manual
generally i do the following:
mc-1 - 80 lb/ft
r/mr/alpha one/gen II - 100 lb/ft
bravo - 150 lb/ft
a careful inspection and cleaning of the threads on both hinge pin and bell housing will determine how to best torque them - if they are crummy, go less, if they are good, do 100
blue loctite on the threads upon installation
