Alpha One installation question - which do you think is easier
Marc Peternell
I have the entire 1987 Alpha One outdrive off of the boat and while off, I went aheand and split it in half for an impeller change.
Which is easier, install the upper back onto the boat and then install the lower?
or
Put the two halves together and then install it onto the boat as a full unit.
I typically put it back on as a full unit. I was only wondering because the upper half is so much lighter without the lower on it. But, I recall from a while back that the lower isn't all that easy to install with the upper still on the boat.
Just seeing if anyone has a preference too.
Fishermark
Re: Alpha One installation question - which do you think is easier
I've heard the same thing. Easier to install the outdrive halves together off the boat, then install the complete assembly on the boat.
I have found the little tool that holds the shift slide to be VERY helpful in installing the outdrive. Inexpensive and easy to use. It's like a third hand!
Fishermark
Here's the tool - the orange thing in the pic below. Priceless! ;)
Marc Peternell
I really like that tool! What is that blue stuff on top of the o-ring for the water inlet? I usually hold mine in place with bellows adhesive.
I actually wish that 2 of the 6 studs that hold the outdrive in were like 2" longer, then it would be so much easier to just hang the outdrive onto those studes and slide it on. Then again, once the outdrive was on, you wouldn't want the studs sticking out 2".
thumpar
I always installed mine complete. That little tool sure would have come in handy but is not required.
Fishermark
I always use grease on the o-ring - not bellows adhesive. It stays in place just fine. I do glue the big rubber ring in for the main bellows however.
Marc Peternell
I glue the big rubber ring too. If not, that one always seems to get in my way for some reason.
Speakrdude
Ensign
Ha! never have seen the orange thing before! Nice idea.
Fishermark
I've had some ask about the tool - it is MerCruiser p/n 91- 865232
JASinIL2006
Any idea of a place online that sells it? Looks like iBoats doesn't carry it, and Mercstuff.com wants a $25 minimum order.
Fishermark
There's one on ebay for $6.59 with $3 shipping. Google is your friend. ;) Or have your local Mercruiser dealer order one.
JASinIL2006
I'll have to look again. I searched on Ebay and came up blank.
kbsunlovers
I ordered my shift shaft holder from the local dealer a few years back. They had it in two days, I didn't have to pay shipping, and I got warm and fuzzy buying local. I think he charged me 8 bucks.
