Alpha one lower housing refitment
salinmar
Have just renewed my raw water pump,plus water pocket in upper housing.Upper gear housing was left on.Now cannot re-fit lower housing to upper as gear shaft splines or something else is not engaging.Lower gear shift is in fwd,prop is locked, etc but no go.Tried turning prop etc.<br />Please help.
Re: Alpha one lower housing refitment
While it's sometimes a Real Pain,......It's All a matter of getting Everything Lined Up.......<br /><br />It seems the Water Tube is the Problem for many people,....<br />For others it's the Shift Shaft,...... Make Sure Everything is In Forward..........<br />The Driveshaft pretty much lines itself up, once you get the Splines right.....<br /><br />And,... Don't let the Quad-Ring slip out of place,.... It'll Leak.....
thunderroad
I fought that last year. I could get it within about a half inch but no further. I was turning the prop....but not enough. I finally just kept turning the prop slowly in a ccw direction, with a little upward pressure on the unit, and it popped in.
salinmar
Thanks guys, will keep you informed from Australia
seldomseen
on alpha one first gen the shift shaft to upper housing shoe can be reached with a finger on the foreward side of the upper housing to guide it in to the shoe. refiting the lower unit is supposed to be difficult.
