Alpha one outdrive
brendanstl
I just pulled my outdrive apart and I have a few question, it's a alpha one gen 1. First off how much oil should have been in it? I attached a picture below showing the only three gasket (one of them being stainless steel) that were below the pump housing but the rebuild kit shows six parts that should have been there, can anyone explain why this was? My last question is, should I replace the pump base as well since there was some melting on the impeller housing and it was run so long with the damaged impeller that the outdrive oil was pure black?
I did inspect everything else as far as how well the shafts turned and made sure there was no play in them or grinding and I think I'm going to check out the condition of the water pocket as well.
Bt Doctur
Re: Alpha one outdrive
1 Go to the Adults Section and download the proper manual for your drive, you`ll need it to identify the correct order for the gaskets.
On average it holds 1 - 1/2 Qts. but you fill from the bottom untill it comes out the top.No guesswork.If the pump base shows signs of melting ,it must be replaced because there are 2 seals the hold the oil in the drive
brendanstl
Yes, I have the proper manual but I was just wondering why it only had three gaskets and if this was typical but I guess the person who did the last pump change missed a few steps and thats probably why the impeller was rubbing aat the top and bottom I know the oild is filled from the bottom but I was just wondering how much was supposed to be in there. Is there anything I can use to flush the outdrive clean before I put new oil in it?
Bt Doctur
Do you have the Mercruiser Manual from the Adults Section?
Let it all drain out and you should be fine.
There is the correct base gasket for your application (3 supplied) , gasket below the steel plate and one above it(the ones with the curved end,and they are specific how there installed)
The gasket on the left you circled is for the Series 1 drive that uses a preload pin in the top of the lower drive shaft.is this what you have ?
no pin ,that is the later Mr,Alpha type and uses a different base gasket.
brendanstl
I have an M stamped on the end of my prop shaft if that helps any and it's an 89. And yes I think I have the proper manual from the ADULT section its manual #6
Bt Doctur
Then the base gasket circled is incorrect for your application
brendanstl
The three that I have circled are the gaskets that were in between the top housing and the base one of them being the stainless steel one.
Bt Doctur
A, under SS plate
B SS plate
C above SS plate
brendanstl
A, under SS plate
B SS plate
C above SS plate
Ok, this helps a lot but I'm still confused of what the series 1 gasket is and the one extra one in the picture i posted.
brendanstl
This is an exact picture of what was ordered for me (not by my choice) from my local dealer. There is five gaskets here and it looks in the manual like there are only three gaskets that get used beside the ss one.
Bt Doctur
From what I can see, the base appears to be Series1 type, the MR,Alpha has a flatter bottom where the seals are. You will have to remove your base and look at it or post a pic of it. The bases are not interchangable. If you have no pin on the driveshaft you use
Sierra 18-3420 ,If you have a pre load pin use Sierra 18-3417
These water pump kits also fit some of the Mercury outboards, the reason for the extra gaskets and O rings
brendanstl
Do you have a picture of what I should be looking for on the driveshaft?
brendanstl
LOL.... no wonder I didn't know what I was looking for because my outdrive is missing the pin, there is a spot for it but there is no pin and it does have an o-ring grove. Now the question is where is the pin, I looked in the shaft and in the upper housing and there is no pin.
Is it likely that someone didn't know what they were doing when they changed the pump last time and put the wrong one in because my base looks like the 3420 base and it has a hole in the shaft for the pin but no pin. My S/N number is 0C695871
Bt Doctur
When you remove the base from the drive, look inside and compare what you see with page3B-35 ,pic #4, "B" retainer.
brendanstl
Does this help any?
Bt Doctur
That the MR,Alpha .It does not use the preload pin. Your kit should be 18-3320.The gaskets needed are the 4 in a line in my pic
brendanstl
Thanks a lot Doctur!!!!!! I guess I can stop looking for the pre loaded pin.....LOL
