Alpha one outdrive
Jaysalman
Looking to pull my outdrive off my boat for storage and inspection 1989 mercruiser alpha one do I need to drain the oil in the lower unit or is it okay to keep it in I just recently changed it out? Thanks
QBhoy
You can take the drive off without draining the oil, but you will lose a little bit of it for sure.
Either way...it’s not a terribly expensive thing anyway.
If it’s the alpha of the later type...remember and undo the header tank pipe work before removing it. Otherwise you will break the fitting. Quite a common mistake.
