I replaced my trim pump assembly this evening. Reason being, the old one acted up and considering the unit was 21 years old I decided to replace it. Previously when trying to raise the outdrive with the helm switch it would stop after only a few seconds. It would go down fine. My trailer button would work, to bring it up. Not sure why that would work and not the helm? Then I decided to raise and lower again and it completely failed.
So, I installed the new asm today. Powered her up and with the helm switch the unit started to raise, then it stopped just like before. Trailer button again worked. But I stopped before that completely failed again.
I recently had the outdrive serviced. My trim senders were cut and not operational. So I ordered new ones and had them installed. We adjusted them at that time. So I assume thats not the issue. Or could it be?
I am at a loss, not sure what to do or check next? Thanks for any help.
