I'll be taking my boat to a mechanic for this one, so I'm not looking for anyone here to magically solve my problem.......but I'd like to have some conversational knowledge of the potential issues when I talk to him.
1985 Mercruiser Alpha One recently repowered fro 305 to 350 engine. Out on Monday doing a short WOT run to test new prop had it about 4600 rpm, 48 mph and I was tapping the trim out a little to max out speed (my trim limit is inoperable so i can't be sure i didn't go too far). Anyways, the prop stops and I shut it down fast. When I re-start, the engine sounds fine, but just revs when I try to go into forward, no boat movement at all. When I try reverse same thing except the engine stalls also. So I get towed in.
I tried to move the prop by hand when in gear and it only moves one way with quite a bit of my weight on it, so I assume not a spun prop. I have read here that a misaligned engine install could quickly ruin the coupler so I'm wondering if the guy who installed my 350 engine messed up. he said the engine mounts were very sturdy and the bolts caught fine so I don't think I have mount rot issues (unless he missed it).
The marina guy (not the mechanic) said likely a coupler issue or the gears are fried. Seems reasonable to me. I don't have the boat here so i can't check anything right now but I might tomorrow.
Any other thoughts on what may have happened?
