Reorandy
- Dec 14, 2011
- 23
I watched a very informative video on the sterndrive install process on Youtube. At just about the final step in the process, the outdrive wouldn't slide quite all the way in. He rotated the prop CCW slightly and it popped right in fully. Great! Only question is: If you align the shift shaft straight forward by rotating the shift shaft clockwise while turning the prop counter clockwise ensuring it is straight by locking it in, how does the prop rotate in reverse when you are aligning the splines? Does that make any sense? In the video he spun it CCW to make the gears mesh up, but it won't spin that way when everything is locked into place. Turning it CW will mess up the alignment of the shift shaft, I believe. Am I missing something here? I have the Spline coupler grease on the splines/shaft, gasket on bell housing, 4" Bellows O ring in, water passage O ring in, and ready to slam it in, just hung up on this one thing.... I made this same comment/question on the video, but he gave me some smoke and mirrors answer, with no clarification. I know I can count on you guys to clear this up!
