Alpha One Sterndrive removal (Gen 1)
neilmw
Took the top cover of the sterndrive to find that some of the baring had came apart and there are teeth missing from the drve and driven gears.<br />I have a manual and it doesnt seem to complicated to remove the the drive casing off the transom, but is there anything I should watch out for or is it fairly straight forward? Also any ideas how this could happen, the oil level seemd fine and dont remember hitting anything?
BMDODGE
Re: Alpha One Sterndrive removal (Gen 1)
pretty easy to take drive off - manual will be a big help ... just make sure shifter is in full forward position. are you having it rebuilt ?? a replacement ?? Good Luck - Bruce
