Curious to see if anybody has attempted to remove a transom assembly without pulling the motor.
I have a leak that I need to fix before I launch in the spring that I THINK.... might be the exhaust pipe. In order for me to fix it I need access to the bolts that attach the pipe to the transom plate. There is NO WAY to reach them with the motor in the boat.
Instead of pulling the motor and being able to remove the pipe, then change the gasket and re tighten, I am wondering if I can just remove the transom plate and leave the motor in place and then re install the transom after the pipe is replaced.
I know its not difficult to pull the motor it's just that the boat is 27ft and on stands. In order for me to pull it (It's a merc 470) I would have to build a whole elaborate gallows style stand and then have to work under the hanging motor or build another stand to work under while the motor is resting on top of it.
Once I confirm the bad exhaust I wanted to have a plan of action...anybody have any ideas?
