alpha one trim bushings
wncrjb
I have a 1988 alpha one with a 3.0 motor. my outdrive serial number is OC443274. I cannot find the outer tilt / trim bushings part number anywhere. If anyone can help find me a sierra or mercruiser part number,I would really appreciate it. I see all kind of bushings but none say for alpha one, and I don't know if mine are the same as other models that are listed.
thanks.. Russ
Haut Medoc
Re: alpha one trim bushings
Look at Doug Russell or bammarine sites.....JK
Bt Doctur
Early Series`1s used a small bushing23-89574
Alpha`s use a large bushing 23-99291
check the casting # on the ram itself 98703,98704
14034,14035
stevieray
ebasicpower.com has a good selection of parts & kits with descriptions & pictures. Good prices & service.
Don S
For the SN you posted, you need the 23-99291 bushings.
