Alpha one trim cylinder question
Bratcher4079
I have an alpha one drive that got stuck in the down position on the lake. Couldn't get it up to trailer home so I pulled the the trim cylinder pin by the prop to release the drive. I fixed the electrical issue but now I need to know how to reset the cylinders so the trim position will match the gauge. I can't put the drive in its lowest position since it hits the trailer. What option do I have? I tried extending the rams to there full extension and installing the cylinder pin but that still doesn't match to the gauge.
HT32BSX115
Re: Alpha one trim cylinder question
Howdy,
You have some other problem with the trim gage circuit. The trim cyls have nothing to do with the trim gage (sender).
It's just a simple variable resistor on the side of the drive. There is slight adjustment possible by loosening the screws at the sender and moving (turning) it in the slots provided.
Here's a great Youtube video on changing the trim limit and sender for a Bravo. Your Alpha is similar.
Mercruiser Trim Sender & Limit Switch Replacement - YouTube
