alpha one water pump
blackz3
Just finnished putting a water pump in a 1988 5.7L merc alpha one out drive...everything seemed to go ok until i fired her up. it now starts in drive even tho the lever is in the nutral position...and if i try to put it in foward or rev it stalls instantly..what did i do wrong!! and how do i fix it<br />thanx<br />WP
Don S
Re: alpha one water pump
You probably didn't have the shifter aligned properly when you put the lower & Upper back together.<br />Look at the section in the site below titled "Gear housing installation"<br /> Water pump installation <br /><br />Do you have a manual of any kind?????
snowmon
Hi,<br />Remove the lower half of your drive. Put your shifter fully in forward gear. . Turn the shift shaft coupler on the lower half clockwise all the way and then reinstall the lower. The reason your stalling is due to the shift interupt switch which will react this way due to the incorrect reinstall of your lower unit. It is designed to momentarily kill the engine to eliminate the load so you can shift from forward to nuetral and reverse and vice versa. Its that micro switch on the shift plate mounted to the starboard riser. Hope this solves your problem.
blackz3
thanx.... now iv found other problems. im knocking them down one at a time. thank god its winter
