Alpha One Welch Plug in Upper Housing
76SeaRay
On the Starboard Side of my upper housing of my Alpha One is a plug. (1985 MR drive SN 6908762). The parts diagram calls out a pipe fitting and a "Welch" plug. What is this use for? I am planning to bead blast the unit and re-paint. Should I remove the plug and get a new one?
I should mention I am rebuilding the drive so would there be anything under the plug that needs cleaning?
Ayuh,..... That hole is used only durin' the manufacturin' process, 'n is then sealed, water tight, with the welch plug,.....
If it leaks, I believe it fills the shift cavity with water,....
76SeaRay
Hmmmm, I wonder if it should be replaced with it being over 35 years old?
