Alpha water pocket tube loose
thejeep007
Working on the boat dropped the lower and the copper tube came out still in pump. Went to push it back into the pocket and loose as a goose. Never had this happen before. Other times the tube seemed snug in the pocket. Normal? Should there be an option ring or something to seal and hold it in place? Thanks
thejeep007
Is that the rubber band looking thing that comes with the water pump kit? Can't find just a collar for sale. Thanks. Must of dry rotted out....
Bt Doctur
18-3110 #43
thejeep007
Nope didn't see anything in the pocket or on the tube. I'll have to drop it again. Thanks
Alumarine
That rubber band thing is probably the slinger which goes on the drive shaft on top of the water pump housing.
thejeep007
Hey thanks that part number made it a lot easier to find the part! Ordered and on its way!
