Stan's Customs
- Oct 30, 2004
- 161
Greetings Mariners..<br /><br />1984 5.0 Mercruiser Alpha 1..Four Winns 190<br /><br />Well I'm tired of waiting for my new Mercruiser manual to arrive. So I searched the archives and got a little info, but just want to ask a couple of questions..<br /><br />First off here's the run down..<br /><br />There is a little water in the drive bellows (tea cup about)...The noise I was hearing is undoubetly from the Gimbal bearing...reached in and felt as I turned it. Feels like a bad wheel bearing, turns but pretty rough.<br /><br />The U-joints both feel good no slack or roughness...Both are rusty and sorta greasy on the outside..<br /><br />The bellows look pretty good to me..no splits etc.that are visible. The large seal that the out drive slides thru looks like it has been leaking into the bellows, on the bottom side..but there's not supposed to be water between the bellows and the drive housing right? If so the shift rail seal from the exaust passage or the o-ring from the water passage has to be leaking into that area correct?...there is a good bit of white sandy looking crud in that area too..indicating water from the looks of it.<br /><br />I have just replaced a bad exhaust manifold that put out a lot of steam..if that is a factor...and <br />the out drive oil when changed was black and cruddy...couple of teaspoons of separated water when first pulled the plug..Wasn't milky though, if that it a factor.<br /><br />Now, from what I've read I really don't to replace the bellows unless it would be foolish not too..What's the scoop here. OK to replace the gasket and seals (including shift rail seal) before the bellows on the outdrive and reassemble ...Or??<br /><br />Also it is not clear to me if you can replace the Gimbal bearing without removing the bellhousing ??<br />I found a diagram on how to extract the bearing ...but it's just out in the open, no housing pictured.<br /><br />Also should the u-joints be replaced..they are oily rusty but smooth feeling without no slack.? Well, a little inside the gear case....like rocking a pinion back and forth on a car...same same.<br /><br />Seems like most of the archives just replace everything ...what should be done here?<br /><br />Thanks and best regards...Stan M
