alternater
wermjr
is there anything wrong with using a car alternater instead of a marine alternater?
cpasseno03
Re: alternater
Not sure, But I think marine alternators are simply sealed off better, perhaps insulated more too, to prevent any sparking. I think you should be fine if you use the blower like usual...<br />Once again, Im not 100% on this.<br />Craig
petryshyn
Re: alternater
I wouldn't advise it. The marine alternator has flame arrestor baffles that reduce explosion potentials. Its not worth the risk if the blower quits..... :( <br /><br />There are conversion kits available that supply these baffles....
Re: alternater
Don't Do It.... It'll turn a Fun Day, into a Tragedy....<br />Marine units are in fact Spark Sealed.....
magster65
Re: alternater
Ditto... don't do it. If you're having troubles have your marine unit rebuilt, it's a lot less expensive that a new one.
MrBill
Re: alternater
Ditto again....and same goes for other components like...starter, voltage regulator, battery, etc.
codyandamber
Re: alternater
Technically, you can use it, but like some of these other guys said...DON'T. It is also against Coast Guard regulations if your gas tank in the aft end of your boat and the fumes could be exposed to the alternator, carb, distributor... That kinda stuff.
