Alternative for OEM Ignition Cables
jtm3
Wondering if there is an alternative to V/P ignition cable kit 3857169 (my engine is a 7.4l GIPEFS - it looks like the main issue is the straight boot on the actual spark plug so it doesn't conflict with the manifold. Thanks - [h=1][/h]
Ayuh,.... Donno what options yer lookin' at, but automotive spark plug wire sets are Waayyy too short to work on a boat motor,.....
alldodge
IMO would suggest any wire set that will fit and is of good quality. quality is a vague term, but no cheap, use silicone large diameter, and resistance wire set. The wire sets of the you make them to fit is a good option.
The 8.1 wires are thru the roof expensive and for the main reason is because there are not very many of them. There is a guy on OSO (BUP) that sells sets for a better price, but how good don't know
have you looked on iboats for the sierra set?
Posting for OP... sierra ignition components are now Mallory
jtm3
Thank you Gentlemen - OEM it is I guess. The challange is finding them/getting them. Sierra doesn't carry a set that would work. Just was wondering if I might be missing something obvious in my search.
CJK440
I just replaced wires on my 4.3 and they are routed round the back of the block and under the risers, a pretty short route to the plugs from the cap, in fact I don't know a shorter route. If an automotive set is much shorter I don't see how they could work with the basic engine architecture. And I would guess an automotive set for the same engine would route over the valve covers and around the exhaust manifolds and perhaps need to be longer. Maybe I am missing something.
A cut to fit plug wire set would be safe. Or perhaps find a manufacturer that lists wire lengths for their automotive sets and compare to your OE set.
jtm3
Clearly my google search skills leave something to be desired.....I didn’t find the Delco alternates. Thank you
