Re: Alternator and Carb Questions 2002 Yamaha
Perhaps my post is a little light on detail. Unless one has a working knowledge of Ohm's Law it will all sound like crap. Voltage current and resistance are all related. Voltage is simply electrical pressure and while not always, it can be related to water pressure and an analogy can be made. If you have a lot of pressure (voltage), there is the potential for a large flow (Current = amps)but this depends on restrictions such as the diameter of a pipe (electrically, resistance). Voltage is also referred to as potential difference. This is important when different electrical sources are in a circuit, in your boat the alternator and the battery. If you have a flat battery the voltage that it holds will be like say 10 volts. Run your motor and the alternator produces say 14 volts, a potential difference of 4 volts leads to a considerable charging current. As the battery voltage or charge improves so the potential difference reduces and so the current(ammeter) reduces and more than likely the reading on your voltmeter increases. Introduce resistance between the alternator and the battery by way of say a bad or dirty terminal or earth voltage or pressure will be dropped across that resistance leaving less potential difference and less current and thus charge. This applies equally to motor off situations. Switch something on that has little resistance and you will have a large current flow... ammeter up and voltage meter down. Introduce poor connections or small guage wiring or bad earths to your anciliary equipment like lights radios etc because of those restrictions it is hard for the battery to push that power through (Small Pipe)and you will have voltage drop along the way resulting in low voltage available at your radio. While your ammeter will show little discharge and your volt meter slightly less reading there still may not be a good enough voltage to operate your equipment properly.<br />Thus the higher the voltage or potential difference the greater the potential to produce electrical current. The higher the resistance, the less the current flow.<br />So, poor connecions, dirty battery terminals, low level of battery acid, poor or corroded earths, light guage wiring and lack of maintenance are boaties worst enemies.<br />I hope that helps.
