Alternator and fuel pump on Volvo Penta 3.0 GLP-D
kwanza1
After doing some fixes to my cooling system, I took the boat for a test ride.
One of the first out-of-ordinary issues I noticed straight after launching and starting engine was that my dash voltmeter was indicating 12 V, while it usually indicates 14 V. The battery was charged, having spent the previous 24 hrs on a charger.
Other gauges behaved as expected, but the dash voltmeter would not go above 12 V.
After approximately 7 km / 20 minutes of cruising on a flat water, with ~22 knots, ~3000 RPM, my engine suddenly shut down, and I was not able to restart. Cranked, turned over, no start. Checked for spark, it was OK. the cut out was surprisingly brisk, not loosing power and slowly dying out, but almost very quick shut-off. My fuel gauge indicated half tank, as expected, and I added more fuel once arrived home, as a check. All fuses seem intact, did not check relays.
Fuel filter is approximately 2 years old.
Is it possible that my dead? alternator impedes fuel pump to function?
I did disconnect what I think is the fuel line into the carburetor and can't notice any fuel being pumped either while manually priming or attempting ignition. I am referring to the silver metallic pipe entering the carburetor on the left side of the image (flame arrestor removed only for these tests)
How can I check alternator in a no-start situation, or how can I check the fuel pump?
At ignition, I have a default alarm that only goes off after successful ignition, so can't really listen to the fuel pump....
Thank you for any suggestions.
Grub54891
Sounds lik your alternator is bad, but I would be removing and cleaning all battery connections completely, in clouding the grounds on the block. Get a hand held test meter, charge the battery fully, test battery before starting, then test after startup, you should get 13-14 volts from the charging system.
Anything less than 12 volts will cause sudden shut down as you describe.
alldodge
@kwanza1 noticed in your first post you mentioned that you were unable to get into your original account. Guessing it was @Kwanza so maybe @tpenfield can assist
I don't have a wiring diagram for your exact model but do have one for GL-E which also uses the EST ignition. With the ALT not working this can mean power is not being supplied to the fuel pump when running (green wire and Diode).
No fuel being seen when cranking can mean power is not being supplied on the Yellow/Red wire, the other diode (23) has opened up, fuse (26 - 7.5 amp) blew, the relay (25) or fuel pump is defective.
Check voltages and fuse
Lou C
Agree with starting with making sure all the wiring is clean, not corroded at terminals,etc. If you have wing nuts retaining your battery cable terminals, get rid of them, they loosen and cause these problems, use locking nuts instead.
Don't forget the large cannon plug, these can get loose and cause problems like that. One time I had a no-crank, no gauges issue but my tilt n trim worked. Cause? an oxidized old school glass fuse in the main fuse box, cause was just oxidation impeding current flow. So, it doesn't take much.
I'd start by pulling out the ignition switch and checking for battery voltage between these terminals and ground:
B terminal (battery, red wire) you should have battery volts with the battery switch on
I terminal (ignition, purple wire) you should have battery volts with the battery switch on and the key turned to the first notch after off
S terminal (start, red/yellow wire) you should have battery volts when the key is turned to start.
some ignition switches have an ACC (accessory) position, but most older boats do not.
If this reveals a loss of voltage, you have to go back and find the source.
With battery cables they can rot under the insulation and cause high resistance, make sure the (negative) return path (we call it grounds, but it is really a return path for DC current) is as good as the positive side. Automotive non-tinned cables are junk in a boat, if that's what you have ditch those and start with new. On my boat I bolted marine quality automotive style clamps onto the cable ends, that way when they start to get too oxidized I can just bolt on new ones.
MarineSp
Alldodge's wiring diagram is spot on — on the GLP-D the fuel pump is electric and gets its power routed through the alternator circuit via that diode. So yes, a dead alternator can absolutely kill your fuel pump even if the battery is fully charged. Its a wierd design choice but thats how Volvo wired these.
The sudden shutoff you described (not slowly dying but a quick cut) is classic fuel starvation, not electrical. If it was ignition related you'd usually get sputtering or misfiring first. The fact that you have spark but no fuel when cranking points exactly where everyone is looking — fuel pump circuit.
One thing I haven't seen mentioned yet — the GLP-D uses a mechanical fuel pump driven off the camshaft, BUT it also has an electric fuel pump assist on some years. If yours has both, the electric one is the likely culprit since it ties into that alternator circuit. Worth checking if you have one or two pumps. The mechanical pump alone should be enough to get it running at idle even if the electric one is dead, so if your getting absolutly nothing at the carb inlet theres something else going on upstream — maybe a collapsed fuel line or a stuck anti-siphon valve at the tank.
The 3.0 GLP-D is a 181 ci inline-4 with 9.6:1 compression by the way. If compression is good and you sort out the fuel delivery this engine should have plenty of life left in it.
kwanza1
Thank you for the useful info. Whether I have a mechanical pump or not, not sure, I can only see a single fuel line coming from what I suppose is the electric fuel pump. Unless the mechanical pump is the one I use to "prime" the cold engine. Could not see any fuel coming through the disconnected inox pipe neither with a crank or a manual priming. Therefore, it is possible I have some fuel line issues further down. I attach some images of what I think the fuel pump and the fuel line are. I looked for fuel being supplied to the carburetor through the inox pipe entering the engine side of the carburetor, and also through the yellow rubber tube entering the back of the alternator.
While keeping in mind that my voltmeter only indicated 12 V with the engine running. I also measured the voltage between ground and each of the two brown wires connected to the back of the alternator, and there seems to be a problem here:
Brown wire (engine side): 0.03 V with key OFF, 12.5 V with key ON. This seems correct.
Brown wire with white stripe: 0 V with key both ON and OFF. Apparently this should always read 12 V.
All fuses are good. Also swapped the "ignition relay" with a different one, no change.
Thank you.
kwanza1
Thank you, hopefully we will up and running, and back to 14 V on the gauge!
kwanza1
Thank you, will work through this!
kwanza1
Thank you, will work through these steps!
kwanza1
Update:
connected a fused line from battery plus terminal to the sensing port of the alternator (which shows 0 V, and it should show 12 V), started smoothly, and both dash voltmeter and multi-meter show 14 V.
Am I too irresponsible going out to a sea trial? Good weather, member of marine rescue....
alldodge
Your motor does not have a mechanical fuel pump
You have a break in a connection, don't know if that is inside the ALT or a wire. What your doing is back feeding the circuit
The relay wasn't working until it was back feed
Remember you have 2 diodes feeding the fuel pump relay, find them and use meter on diode scale to check them
You know the motor is running so taking it for a sea trial is only going to verify the failure has been bypassed, not fixed
kwanza1
Thank you.
I have to correct my earlier update. The fused line from Battery+ was not connected to the alternator terminal where the sensing cable connects, but to the sensing cable (brown with white stripe) itself.
I am now confused as to how did my engine start and why does my dash voltmeter shows 14 V (charging battery)? That is, the alternator terminal where this sensing wire connects has nothing connected to it now, and the cable itself receives the 12+ through a fused wire from the battery. Wouldn't I need the 12V on the alternator terminal itself to signal that the 12V is present, go ahead and charge?
Apologies if I don't make sense.
I ran the engine on garden hose for 10-15 minutes, with no other noticeable issues on the dash or under the engine cover.
alldodge
The left side (12V from Bat) wire is what should go to the choke coil on carb
Peal the insulation tubing back from wire on the right to find the other wire that should be connected to the other
MarineSp
Good news is the alternator itself is fine since it charges at 14V once backfed. Alldodge is right about peeling back that insulation — on these Volvo harnesses the wires splice inside heat shrink or loom tape and those splices corrode over time.
I'd bet theres a corroded splice or broken solder joint under there. The brown/white wire feeds both the alternator sense and the fuel pump relay through those diodes, so one bad connection took out both systems at once. Explains everthing.
When you find it, solder it properly and use marine grade heat shrink with adhesive lining. Dont use crimp connectors in the engine compartment, they just corrode again.
And dont leave that bypass wire as a permanant fix — it works but it skips the diode protection and you could backfeed 12V into places you dont want it.
kwanza1
An update on the above issue.
I will probably wait until I can take the boat to the mechanic, as I am afraid of doing further damage....might have already done it.
Tried peeling back the insulation tubing on the wire on the right, I stopped at the zip-tie in the image. I will go further once I cut the zip-tie.
I opened the cannon-plug, there was a fair bit of yellowish residue, and cleaned it.
Boat still only started with a fused jumper cable 12+ from battery to the alternator sensing cable (brown with white stripe). Jumper cable connected only while running the engine and boat.
Alternator indicated 14 V, and everything seemed to run OK.
Embarked on a approximately 30 km (total) return trip. All gauges indicated nominal values, 14V, correct oil pressure, 3100 RPM, correct temperature, good noise, nothing suspicious.
Completed approximately 28 km, when engine shut down, and I was back to the initial symptoms: no start, spark present. Inspected jumper cable, replaced the whole cable with a new fuse, however I was not able to restart. My battery took a battering, but still showed around 12 V.
Another thing I noticed was that if I turned on my blower, dash voltmeter went down to 12 V. Off, up to 14 V. I did the trip with blower off, starting engine with open cover. Maybe the blower is causing all this?
I suppose next time I'll be more patient, less greedy, and wait until a proper fix.
Thanks everyone for your help.
alldodge
There is a bad connection somewhere
My thought is that the wire would be close to the end of the tubing. Try looking at the other end of tubing and see how many wires are inside
kwanza1
Thank you.
I'll keep checking, and will clean other connections as well.
Will attempt disconnecting the bilge blower, to see if that makes a difference. Bilge water pump, nav/anchor lights, drive up/down switch did not have an effect on the voltmeter's 14V, only the bilge blower was knocking it down to 12V. And that only started two days ago, before that was OK, I usually had the blower running while out.
Also, at the right hand side wire (pointy end of my longer red arrow), the black prong is just a rubber plug...not a broken wire. There was never any other wire connecting to this connector since I owed the boat, ~6 months, and I did not touch any of these wires on the alternator before. But I'll dig a bit deeper here.
MarineSp
The blower dropping voltage from 14V to 12V is a big clue. That means the alternator cant handle even a small extra load — which points to a high resistance connection somewhere in the charging circuit, not the alternator itself (since it does put out 14V unloaded). A healthy circuit wouldnt flinch at a bilge blower.
That rubber plug on the right prong is interesting. On some GLP-D harnesses that terminal was used for an optional tach signal or second sense wire depending on the year. If its always been empty on yours thats probably fine, but worth confirming with your mechanic.
Smart call waiting for the mechanic at this point. The bypass got you home twice but the fact that it died again after 28 km suggests the bad connection is heat-sensitive — runs fine cold, resistance goes up as the engine bay heats up, and eventually the voltage drop is enough to kill the fuel pump relay. Thats actually helpful diagnostic info for your mechanic — tell him it runs 20-30 minutes before cutting out
