1998 Bayliner 2355 with 5.7 litre Mercruiser and Alpha I. Does anyone know if the alternator bearing can be replaced? It makes a bit of a squeek at idle that dissipates as the RPM are increased. I took off the belt and spun the alternator by hand and it is definetly the culprit. Altenrator is charging fine but I certainly don't want to be out on the sound when the bearing totally fails.<br /><br />If it can be replaced is it the sort of thing that I can do or does it need to be pressure fitted on?
