Re: alternator conversion
Chances are the 3 wire alternator is externally regulated. A one wire style would be internally regualted. In order to make the switch you would simply just need to bypass the regulator. I've done it on older cars many times.
If that is the case:
Trace your wiring back from your alternator and find the regualtor (should be a little box with some wires going into it and one big wire comming out and going to the battery). Depending on the type of one wire alternator you are looking at, some really take 2. One is a smaller one and one is the main one to the battery. The small one gets wired into a key switch to "excite" the alternator field when the key is on, the other goes directly to the battery. True one-wire alternators only have one post which goes directly to the battery and serves to both excite the field and charge the battery. If it is a true one wire, simply remove the heavy lead from the regualtor, and wire it directly from the alternator to the battery. Make sure to remove all the old wiring you are no longer using.
