Lukelona
- Mar 9, 2013
- 449
Does anyone have 3.7 Mercuiser with the alternator modification done to it?
Mine has power steering and is all stock.
Looking to do alternator modification as preventive maintenance, but I don't have much room in the engine bay.
My motor sits down in the bay where deck is about at the top of stator, with 6-10" maybe on the side.
It seems like the pics I've seen of alternator mod the alternator stocks out to the side quite a bit, which I won't have the room for.
I'm gonna make my own brackets regardless, and just buy alternator separate.
Can someone measure how many inches from furthest point of alternator to the widest point of engine for me?
Probably the cooling hose far starboard side to edge of alternator?
Trying to see if I'll have enough room or if I'm stuck with this stator setup.
Also, I've heard of adding a different voltage regulator like a automotive style but I'm not sure which one would work, or if it would be safe (explosion etc)
Thanks in advance
Thanks in advance
