Alternator on Pontoon boats?
smacs2080
I know this may seem really silly, but my husband and I are new to outboards, let alone pontoons. Do they have an alternator or some kind of recharging system for the battery???
BaileysBoat
Re: Alternator on Pontoon boats?
Welcome to iboats.
Did you read the operators manual? Most of the larger outboards will keep a battery charged. What kind of outboard do you have?
rickdb1boat
Generally speaking, if the motor has electric start and is a fairly recent model, it will havea charging system. But knowing your particular model would help..
Silvertip
Look at the instrument panel? Do you see a "Voltmeter". If you do, there is a good chance the engine has an alternator. If not, you will need to tell us what make, year, and HP engine you have.
smacs2080
I am sure we have the operators manual. It is a 2009 Sun Tracker Party Barge 21. I will look for that and the voltmeter. Thanks everyone!!
imported_John o
(Just in case)
DO NOT run the motor without a battery attached. Do not disconnect the battery once the motor is started. If you have a battery switch, do not switch off the battery with the motor running. Any of these will fry your alternator.
(again, just in case, better to be safe than sorry)
