Alternator Question
Boilers2000
Alternator question
I want to install a blue sea ACR and want to fully understand the wiring of the boat. One question I have is around the wiring of the alternator. I have a 92 4.3LX. I have 4 wires coming from my alternator..my question is around if my understanding of these wires is correct. According to the service manual:
1. Black - ground
2. Orange - output wire. This wire is shown running back to the stater solenoid and I believe is what passes charge back to the battery so the battery can recharge.
3. Purple - Excitation Lead. This is shown running to the ignition coil and I believe provides current for the spark plugs
4. Red/purple - Sensing Lead. This is shown just running to the molex of the wiring harness. I believe this is what runs to the dash gauge for voltage reading.
Is my understanding correct or am I missing something.
Thanks in advance!
Boilers2000
Posted on another thread but didnt get a response, thought I move to here to see if any of the speedy responders knows.
1. Black - ground
Thanks in advance!
Bt Doctur
click to enlarge. the "sense" is a constant 12v supply, the "excite" gets power from the key switch in the "on" position and also power the coil
muc
"Retired" Association of Marine Technicians...
#3 is what powers the volt gauge
#4 is always hot battery voltage
not sure what a “molex” is?
Bt Doctur
Really , look at the wiring . The sense is always hot and the excite GETS its power from the key switch because that purple wire also powers the coil
jbcurt00
Boilers, dont start multiple topics about the same subject
Merged
If you think a topic would be better served in another forum, ask a Mod to move it for you, dont start a 2nd topic.
8 or 9hrs between posting and getting a reply isnt unusual, it is the weekend. Members have boats and lives, so they might be busy elsewhere until dark, or later.....
Boilers2000
Sorry JBcurt, wasn't sure of the proper merging protocol and/or how to reach a mod.
Bt Doctur, I think my thought is aligned with you...so then does the orange wire create the path from alternator to starter solenoid to battery. Trying to trace the path current flows from the alternator to recharge the battery.
Muc, moles is what air was calling the ten-ish pin plug that most of the engine wires terminate to.
Thanks again everyone
Bt Doctur
it goes from the alt output directly to the starter solenoid main battery post sometimes thru a 90A fuse link.
#16 in my link
