Alternator questions
brian3127
I have dual mercruiser 260's on my new to me boat. Do both engines normally have an alternator on them.
I think one is bad just wondering if 1 alternator is enough to charge the batteries. Never had dual engines before so this is all new to me.
Ayuh,...... Only 1 should be charging the batteries,....
cyclops222
On 2 or more engines in a boat ? It is common for only 1 engine to have a alternator AND a Power Steering Pump. They run just fine that way.
alldodge
Guess I'm going to be scratching my head some, but every twin engine boat I've seen has 2 Alt's. Each motor charges it's own Bat, and one of them charges the house Bat
brian3127
the engine that has the bad alternator has the power steering pump.
I guess in the spring I will have to chase wires on both engines and se which engine is doing what.
Bt Doctur
The standard configuration is one system for each motor
each motor has its own gauges .Charging systems are NEVER combined between motors.The only thing connected to both motors should be a Neg battery cable ,engine to engine
Ayuh,...... Donno what I was thinking,.... speed reading, but not speed thinking, for sure,......
Disregard my posts above in this thread,..... AD, 'n BD are correct,....
