Hi
Just bought a 1975 Glastron Vagabond with a OMC 190HP Ford 302 Stringer Sterndrive with select trim.
Just getting ready to do a tune up having spent last week draining 3 year old fuel, new filters cleaning the carb etc.
In the water I'm getting
Overheating at full throttle
Poor charging
Maxing out at 3200 RPM
The electric choke doesn't appear to be moving the plates when power is applied from cold.
Oh and as an added bonus while idling along ran the prop over a rock and destroyed a perfectly innocent prop that had never done anything to offend me.
I can spin the alternator by hand using the fan blades so I'm hoping I'm just looking at a loose belt. Disconnecting the main water feed to the thermostat housing reveals a 4-6 inch plume of water if I point it straight up so I am assuming the impeller is OK.
Low WOT may be very bad timing and a well pitted prop (prior to me destroying it completely)
So my questions are
Does a standard 15 spline prop work for a stringer electric shift?
Spark plugs seem to be recommended as Champion RF10 but I'm struggling to find anyone selling them, any suggestions on alternatives?
Alternator is wired as single wire see pic, is that normal?
The electric choke has good 12V to it but doesn't move, tested off the carb and it doesn't wind/unwind and open circuit so is there a special marine version of the electric choke? also its a one terminal type not the more typical 2 terminal so I'm a bit confused as to which model it is.
Any thoughts?
John
Poor charging
So my questions are
Any thoughts?
John
