Alternator
FreeBeeTony
Noticed when 1st starting the engine this year it took a while for the voltage to increase to >13V on the dash gauge.......more than the usual 1000RPM's........once it did it seemed fine though.
Today I noticed again while out on the water.......is this an indication of a potential problem??
ENSIGN
Re: Alternator
Start removing and cleaning all the wiring connection points,yeah I know it's a pain but something may have corroded over the winter
ButchC
Re: Alternator
Many alternators require an rpm of 1500-2000 to 'kick in'. Once it does you can drop the rpms to idle and it will have the proper voltage.
FreeBeeTony
Re: Alternator
Seemed like the voltage was dropping at idle even after going up after reaching the required RPM's.
Re: Alternator
Ayuh,... Sounds like you're just Lookin' for something to take Apart....:D
Re: Alternator
Ayuh,... Bring your multimeter fishin' with you next weekend if you're worried...
I don't really see a Problem...
FreeBeeTony
Re: Alternator
I actually have a DVM on the boat and did measure the voltage when the dash gauge was high.......the voltage was ~14.5V.
