Alternator
joshstan1978
So I was trying to take the alternator from my 4.3 mercruiser in to get checked and I couldn’t get it all the way off. There was a black box attached to the back of the alternator that had wires that ran into the whole wire harness. Sorry I don’t do electrical work much. Anyway, someone tried to do it before cause I had to drill out a screw. Finally got the alternator off and it smells burnt and sounds like rocks. Lol. Anyway, how do I hook this attached photo back up to a new one?
joshstan1978
joshstan1978
Ayuh,..... Welcome Aboard,..... You don't,.... you replace the alternator,....
If you get the same alternator, it'll have a new box on it,...
nola mike
The box belongs with the alternator. There are bullet connectors that were supposed to be disconnected to remove the alternator, you can see them in your first pic
Bt Doctur
a mando alt and it can be replaced with a standard gm marine alt single wire or three wire
