alum boat holes 5200?
saw some posts here about 3m 5200 you think i can plug some small holes got 15 point of pen size to a 1/4" holes caused by electrolysis did i spell that right? for at least a temp repair?
Bob_VT
Re: alum boat holes 5200?
Electrolysis...... Put a patch ontop, fasten with ss screws or rivits and 5200. or....
Put rivets in the larger holes and use Gluvit. A few coats will do better than 5200.
Ayuh,...........
5200 is Great when it's used Between things,..... As a Gasket Material,.......
It's Not a good Coating.........
I'd use Gluvit for what you propose.......
this gluvit ?from what i read it's best for seeping into rot areas like git rot a product ive used before,but tell me someone thats used it on aluminum does it cling to surface or will it weep away before it sets up?plus it's below 70 degrees now .
