aluminum boat... aluminum stringers?
diaboy5681
I have a 1989 Sea Nymph 175SS Fish n Ski, looking through a hach it looks like I can see a stringer but appears to be aluminum, im 20 and my first boat so any help would be great!
Re: aluminum boat... aluminum stringers?
Ayuh,...........
Aluminum Boats have Aluminum Stringers,.......
Atleast All the 1s I've been Into,.............
diaboy5681
Good, thanks for that, i just wanted to make sure so i can replace the floor, or parts of it and not have to deal with the stringers
tiller7104
LOL Hey hey.... I have put wood stringers in aluminum boats LOL..Diaboy I have you exact boat you have with the exception that mine is a 175 GLS....You have aluminum stringers
Bob_VT
Check the transom wood. If you are real ambitious you can plug the boat and add water to see if there are any leaks.
tashasdaddy
Bob has a good point, check for leaks before you do the floor. if leaking, you can use Gulvit on the inside, before replacing the floor. makes it much easier.
diaboy5681
I might do that, ive had the boat out quite a few times now with no water entering the boat so I dont think there is any leaks.
