crackedglass
- Jan 4, 2009
- 206
I picked up an older Duranautic 14' boat this weekend, got it cheap, but it needs some work. The rear bench seat has a panel beneath it which is welded in 6 places to a strip which is riveted to the hull. The upper two welds on each side are broke free. They attach what appears to be 1/4" aluminum angle to a sheet metal panel which I think is there to provide some support for the hull. In the water, the weld has no real effect but on the trailer, pulling on the sides of the boat will separate the weld. The hull is rated at 40hp, and I intend to hang just that on it, so it needs to be perfect. Does anyone have any suggestions as to rewelding these points?
The hull has no ribs, these are built flat, the seats and the lower strakes give these all their strength. I have a mig welder with a spool gun but am leary about welding sheetmetal this way. The factory has short 1.5" long welds in about 6 places along the bottom of the hull. The boat has been in use constantly, most likely with these welds cracked for many years but I like to make this as rigid as possible since I intend to up the hp from the current 25hp to it's max of 40hp this spring.
