Got the old floor and assorted accumulation of trash/gunk/dirt out of my aluminum runabout today. Huzzah for the shop vac! Can you get panels/sheets of closed cell foam at the box stores? Need to replace the little styrofoam that was below my old deck. What type of screws should I use to secure the new coated plywood deck panels to the aluminum stringers? Will a standard cordless drill/driver be enough to set the screws? Plan to leave the back bilge panel removable for cleaning, water removal, etc. Thanks in advance.
