Aluminum boat
delanesr
Well working on 1991 13 1/2' Gregor. Kind of got the shinny bug , so far I very hit it with 2000 grit wet sand just not happy with results. Not trying to get real crazy but would like it to look nice when done if any one has any tips I am all ears and thanks delane
be patient.
polishing an aluminum boat is a fools errand unless you like re-polishing it often.
however if you are going to do it, here is how
you start at 240 grit, and sand the whole thing, you repeat with each 320, 400, 600, 800, 1000, etc. each unil you get to your 2000.
then you bring out the buffing rouge and wheels and you go over the whole boat doing a color buff. expect to go thru about 3# of rouge and about a dozen wheels
at that point, you removed all the oxides from the outside of it, and aluminum will soon corrode in the open air. do not touch it with your fingers, you will etch your fingerprints into the freshly polished surface. so you have to seal it with sharkhide or similar. once every few months, you will need to rebuff it, and re-apply the sharkhide
a cheaper and easier way is a vinyl wrap.
Scott06
Danforth has it laid out it looks easier than it is. Go to you tube and look videos of guys doing this and pay special attention to the black chit they get covered with head to toe ....
yes you do
you will need a tyvek suit, full face respirator, and a good fan.
aluminum dust is explosive so make sure you work in a well ventilated area. however if you are wet sanding, that will keep the dust down, however the minerals in the water may corrode the aluminum
our stainless buff shop has redundant air makeup units. the old aluminum shop had air makeup units, each person had a full respirator helmet with its own filtered air supply, the sanding booth also had fire suppression (we no longer polish aluminum)
cyclops222
I did the polishing of the rear bench seat . WARNING !!!!!!!!! The reflection is so intense that you can not look in that GENERAL DIRECTION !!!!!
Can you enjoy driving a car, if there are loads of reflections, from cars ahead of you ?..... Same annoying glare in a polished metal surface. Flat or curved.
You will learn about shiny metal surfaces.
airshot
The few folks that I know, that tried the polishing route, regretted doing it ! The glare off the hull and water was unbearable.....and the up keep was worse !
DeepCMark58A
I had 24 holes filled on my aluminum project boat had to buff those out, all I can say is good luck it is going to take a while.
we are talking the boat in your profile pic, correct?
if so, note the black spots are little corrosion pits. so you will need to sand the whole surface with the 240 grit to get to the bottom of all the pits, then go finer
https://forums.iboats.com/data/avatars/o/550/550258.jpg?1737956229
cyclops222
That hull has weak pinhole spots. Do NOT sand all the way down to eliminate the black HOLES !!!
